Best Grease For Main Gears
Discussion in 'The Chat Room' started by smakmeharder, Jun 16, 2014.
By smakmeharder on Jun 16, 2014 at 5:41 PM
    Whats the best grease to use for the main gears for 550 to 700 size choppers? Shoud grease be used at all?
      And @Jeff B , I STILL haven't harvested the servos out of the 800, sorry, still working, listening to the Red Hot Chilli Peppers - It rocks
    2. Jeff_Bradley
      I am not suprised
    3. feral
      well that got weird quick
      depends where you taste it from!
    5. feral
      Your lucky im not smoking now I would have a scalded throat
    6. simon
      GO TNC
      Really the thread was answered in the first few responses, the rest is shiz and giggles...Good fun
    7. Jeff_Bradley
      Wacked
    8. Johnnybgoode
      Johnnybgoode Active Member
      This forum is so funny man - but still informative.
    9. Min
      Why should synergy gears not be lubed? Matt Botos' gears had this white coloured grease on it.
    10. NevErSn0w
      NevErSn0w Active Member
      i use a fully synthetic grease made by Inox its awesome stuff, apply a little with a tooth brush and it works a treat! you can even eat it @simon
    11. NevErSn0w
      but... could you use a carbon based grease?
    12. Jeff_Bradley
      Min, delrin doesn't need greasing as they are self living. Are you referring to main gear and pinion
    13. Min
      yeah, all the teeth had this grease that could be scraped off and was white in colour
    14. Jeff_Bradley
      That would be one way bearing grease
    15. beenflying
      beenflying Member
    16. beenflying
      beenflying Member
      Here's the Dryfluid heli trailer:
    17. Manyc
      @5Fidy is ordering now... they used a logo in the ad...
    18. smakmeharder
      LOL... to true... the dryfluid looks awesome, the piroflips were much smoother! But really I wonder what chemicals make up that lubricant, weather it be silicon or carbon based.
    19. NevErSn0w
      Gotta say that logo did look pretty shmexy
    20. jockstrap
      jockstrap Active Member
      That's interesting Jeff as the TDR uses delrin gears and Jan says you MUST grease them..
      I noticed a great reduction in gear "whine" when I greased my old TDR gear train.
      I use a tiny bit of this --> http://www.rcbits.com.au/content/tri-flow-clear-synthetic-grease-small
      put a small dab about every cm on the main gear and then spin the gear by hand - it will slowly spread to pinion and evenly around the whole gear.
      The stuff is sticky and thick, which is what you need so it doesn't all "fling" off in flight.. but you only use it "sparingly" otherwise excess just goes to waste and makes
      a mess of your heli - lol
